How To Use An Intrusion Rule On An Amcrest Camera (IP4M-1068EW-AI)
Intrusion allows the camera to trigger an event if an object, such as a human or vehicle, appears or crosses a set intrusion area set by the user. After adding the rule, the interface will display the rule as enabled, use your mouse to draw a detection area on the interface. For more information on how to setup the rule please refer to the information provided below.
.Step 2: Access the AI menu and click Please add a preset first.
Step 3: Click Add Preset and set a preset for the rule if needed using the provided PTZ options. Double click the Name field and enter a name for the preset. Click Apply, then click OK.
Step 4: Click +Preset and add the preset to the interface. Select the preset and click Next.
Step 5: Select the preset, click Add Rule, and select Intrusion. Draw a detection area on the interface and select any other applicable options. Click Apply.
