How The Amcrest License Plate Reader Camera Works In Amcrest View Pro (IP4M-1062EW-AI)
The Amcrest LPR camera can be added to the Amcrest View Pro app if needed, however, is only applicable to live view as the camera does not support video playback, motion detection, or push notifications. It is for live view purposes only.
The Amcrest View Pro app can be downloaded in both the App Store and Play Store.
The following steps will continue the app setup process for an Android phone and, though the iPhone version of the app has slightly different steps, most of this process is identical and easy.
Download and install the Amcrest View Pro app for the App Store or Google Play Store.
Open the app on your mobile device and allow the app to load.
Tap "Start". Tap "POE Camera".
Tap "P2P Connection".  Scan the QR code. The QR code can be found on the serial tag along with the scannable barcode.
Create a name, enter the default password admin and tap Start Live View. Update the default password for the device and tap Start Live View.
