The device can support a microSD card of up to 128GB. Please make sure the microSD card is class 10 or above and properly formatted before inserting it into the camera. To locate the microSD card slot, move the camera portion upwards and open the cover. The microSD card slot is located next to the factory reset button.
Insert the microSD card into the microSD card slot and press in to secure it.
