How To Set Night Vision Settings For Your Device Using The AMLINK Pro App (AL4M-P401W)
The night vision settings on your device can be modified in the video settings menu in the AMLINK Pro app. This camera has built-in IR LEDs to allow the camera to see at night in black and white. These LEDs will be on by default and automatically turn on once the ambient light in the area has reached its threshold. For more information on how to set night vision settings, please refer to the information provided below.
Step 1: Access the Video Settings menu for your device. To access this menu, locate your device on the home menu and tap Settings.
Step 2: Tap Video Settings.
Step 3: Tap Night Vision.
Step 4: IR night vision will be enabled by default, to disable night vision, tap the Night Vision option to disable the feature. Tap it again if you would like to enable it again.
