How to Upgrade Firmware Using the Amcrest IP Config Tool (ASH26)
The firmware for your device can be upgraded manually using the Amcrest IP Config tool. To download the Amcrest IP Config tool, click here
If the cloud upgrade fails on your device or the upgrade has made your device go offline the device can be restored manually as long as your device is still connected to your network using the Amcrest IP Config tool. To download the Amcrest IP Config tool, click here
For more information on how to manually upgrade the firmware, please refer to the information provided below.
Step 1: Download the latest .bin file. You can access the latest .bin file here.
Step 2: Open the IP config tool, select your device and click Login
Step 3: Enter the username and password for your device and click OK
Step 4: Click on the Upgrade tab.
Step 5: Click Open File and access the .bin file and click Upgradeimage3.PNG
Allow the device to upgrade, the device will go offline and reboot. Once the reboot is finished the device will come back online (solid green LED) and you will be able to access the device again.
