How to Upgrade Firmware Using the Amcrest IP Config Tool
The firmware for your device can be upgraded manually using the Amcrest IP Config tool. Before proceeding, please make sure your device is still connected to the same network as the device that is using the Amcrest IP Config tool. To download the Amcrest IP Config tool, click here
For more information on how to manually upgrade the firmware, please refer to the information provided below.
Step 1: Locate the .bin file for your specific device.
Step 2: Open the IP config tool, select your device and click Login.
Step 3: Enter the username and password for your device and click OK.
Step 4: Click on the Upgrade tab.
Step 5: Click Open File and access the .bin file and click Upgrade.
Allow the device to upgrade, the device will go offline and reboot. Once the reboot is finished the device will come back online (solid green LED) and you will be able to access the device again.
1 out of 3 found this helpful
