The camera can be adjusted vertically or horizontally. To adjust the angle of the camera, you will need a Phillip head screwdriver. To adjust the camera vertically, locate the pivot screw on the base of the camera and turn it left to loosen. Once this screw is loosened the camera can be manually tilted vertically up or down. Be sure to tighten the screw securely after it has been adjusted to lock it back into place.
The camera can be adjusted horizontally in two ways, at the camera, or at the base. By adjusting the pivot screw closest to the camera you can adjust the camera horizontally left or right. Be sure to tighten the screw securely after it has been adjusted to lock it back into place.
To adjust the camera at the base, locate the adjustable bracket on the base of the camera and turn it counterclockwise with your hands to loosen. You can then adjust the camera at the base left or right. Be sure to tighten the bracket securely after it has been adjusted to lock it back into place.
