Admin codes are used to access programming mode. The default admin code is 123456. If you have forgotten the admin code for your Amcrest door lock, please refer to the information provided below.
Step 1: Touch the screen to activate the lock and enter the admin code.
Step 2: Tap
> 4 >
, enter the new admin code with 4-8 digits and tap .
Step 3: Enter the new code again, and then tap
. The buzzer will beep and the indicator light will flash green which indicates the code has been entered successfully.
