How to Format a MicroSD card Using the Amcrest Smart Home App
A microSD card can be formatted using the Amcrest Smart Home app. This will clear all data on the microSD card and format the microSD card to FAT32. Formatting the microSD card is performed via the storage status menu in the app.
The storage status menu displays any current cloud or microSD card storage options applicable for your device. This option also allows you view current cloud subscriptions applicable to your device as well as format a microSD card right from your smartphone. For more information on how to format the microSD card, please refer to the information provided below.
Note: A microSD card can be formatted externally as well if needed. For more information on how to format a microSD card externally, click here.
Step 1: tap on the settings icon (
) on the live view screen. Tap on the Storage Status option located in the settings menu.
Step 2: The microSD card storage capacity will be displayed in this menu. If no microSD card is being read by the device the status will be “Disabled”. To format the microSD card, tap on “Format Storage
Device”.
