How To Access An Amcrest NVR Using a Web Browser
This device features the latest in JS technology which allows you to access your device using a wide variety of web browsers including Google Chrome, Firefox, Safari, and other mainstream web browsers. For more information on how to access your device from your computer please refer to the information below.
To access your device from your computer you will need to first locate the device's IP address. To locate the device’s IP address, it is highly recommended to download our free Amcrest IP Config Tool software. The Amcrest IP Config Tool can be downloaded at the following web page: amcrest.com/downloads
In the All Downloads menu, click on IP Config Software to begin the free download. Once the download has completed installing, locate the IP address associated with the device you would like to view in the browser.
Please note, the IP address listed in the image above is just an example. The IP address for your device may be different than the one represented in the image.
Open the web browser and enter the IP address into your browser. Press enter to access the web user interface.
In the web user interface, enter the login credentials for your device. If this is the first time accessing the device, the username and password will both be admin. Click on Login.
2 out of 4 found this helpful
