How To Access A Camera's Web UI From An Amcrest AI NVR
The NVR can provide direct access to a connected camera's web user interface (web UI). This allows for  easy, quick access to the camera's direct UI from one central location to view and modify camera settings. Please make sure your NVR and camera are on the same network during this process. For more information, please refer to the details provided below.
Step 1: Log into the NVR using the NVR's web user interface (web UI) in a web browser. For more information on how to access the web UI for your device, click here.
Step 2: Click Management and select Camera.
Step 3: Locate the camera you want to access in the Add Device menu and click on the icon provided in the WEB Browser option.
This will automatically direct you to the web browser for the selected camera.
0 out of 1 found this helpful
