How To Perform a Factory Reset (ADC2W)
Performing a factory reset on your camera will reset the device back to its original default settings. Please make sure the camera is powered on while performing a factory reset. For more information on how to factory reset your doorbell, please refer to the information provided below:
Note: It is highly recommended to delete your device from your Amcrest Smart Home account before performing a factory reset. For more information on how to delete a device from your account, click here
Step 1: Use the included pry bar to pry the open the security hatch on the top of the camera.
Step 2: Locate the Reset button on the top of the camera. Press and hold the reset button for 30 - 45 seconds allowing the camera to reset.
Note: Do not look at the front of the camera as the deterrent light may still be triggered to come on when it detects motion.
