How To Perform A Factory Reset On An HDCVI DVR
How To Perform A Factory Reset On An HDCVI DVR.
In most cases when a factory reset is required for resolving many different types of issues associated with an HDCVI DVR. Please note, once a factory reset is performed, all settings in the DVR will be lost. Make sure to back up, export/import any desired settings before performing this procedure.
Note: If no button is present then letting system unplugged for 2-3 days should also allow it to initiate the hard factory reset. If the reset went through it should take you to the startup wizard when it boots back up
Factory Reset Procedure:
Step 1: Disconnect the power cord to the DVR. The DVR must continue to be unplugged throughout the process.
Step 2: Press and hold the power button for 3 seconds. The power button is located on the front of the DVR.
Step 3: Wait for a few seconds and repeat step 2 for about 15-20 minutes.
Note: The main goal in this procedure is to drain all power to the DVR.
Step 4: After the 15-20 minutes, please reconnect the power cord to the DVR.
Step 5: After the  DVR completes its reboot process, it should initialize to the start up wizard. On initial login the username and password will reset back to default which is admin for both.
Step 6: Reconfigure the DVR, import all previous settings if applicable and reset all settings previously associated with the DVR.
0 out of 1 found this helpful
