How to Download Events Using Amcrest View Pro
To download events using the Amcrest View Pro app you must have a microSD card inserted into your camera. A microSD card must be class 10 or above and be properly formatted to FAT32 before use. For more information on how to format a microSD card click here.
Once a microSD card is properly installed you can then begin retaining events. All recordings can be retained manually via the playback menu. For more information on how to download events using the Amcrest View Pro app, please refer to the information provided below.
Step 1: Open the Amcerst View Pro app and access your camera.
Step 2: Tap on the main menu icon ( mceclip0.png ).
Step 3: Tap on Playback.
Step 4: Tap on the ( + ) icon.
Step 5: Choose a playback date and time range then choose your device.
Step 6: While the event is playing, use the manual record icon ( mceclip2.png ) or the manual photo (snapshot) icon ( mceclip1.png ) to retain the event to your app. If you are manually recording an event, tap the manual record icon again to stop the recording.
Note: All manually retained events will be saved into the My Saved Files folder located in the main menu of the app.
Step 7: Tap on the main menu icon ( mceclip0.png ) again and tap on My Saved Files.
Step 8: Tap and hold the selected file located in the folder that you want to download.
Note: All manually recorded video events will be stored in the video folder (mceclip3.png). If you took a manual snapshot, click on the snapshot icon ( mceclip4.png ) to access the snapshot menu. If you would like to select all recordings, tap on the select all icon ( mceclip6.png ).
Step 9: Tap on the download icon ( mceclip5.png ) to download the file to your mobile device.
All any permissions requested to download the file. The file will then begin downloading to the photo/ gallery on your mobile device.
