How to Setup an Amcrest Camera Using NO IP DDNS (IP4M-1066EW)
Note: Please make sure your device is connected to the internet.
Step 6: After your device is port forwarded, navigate to the web UI, click on the Settings icon and select Network and click on DDNS and ensure NO-IP DDNS is enabled.
Note: After enabling DDNS function, third-party server may collect your device info.
Step 7:Visit https://www.noip.com/and set up an account with NO-IP. Create a hostname, username, and password and complete the signup process. Please make sure to confirm your email address when activating a new NO-IP account. The Dynamic Update Client (DUC) can be used to manage your hosts and groups within your NO-IP account.
Step 8: Return to the DDNS menu for your Amcrest camera. Enter the Domain Name for your camera into the interface.
This will be the hostname created in your NO-IP account.
Step 9: Enter the username and password for your NO-IP account into the interface and click Apply.
Note: The username and password for your NO-IP account can be found in the Account Info tab on your NO-IP dashboard.
