Amcrest ACD-860B Dash Camera Feature Set and Specifications
The Amcrest ACD-830B is a very versatile dash camera that has several features and specifications in three different camera modes. The following lists are the video, still image and playback features and specifications:
Video Features
MicroSD Card: Supports up to 64GB Class 10, minimum is 4GB Class 10.
Quick Lock: Quickly lock a video while it is still recording.
GPS: Global Positioning System for location and speed monitoring (GPS Module sold separately).
Mini HDMI: Display video from the camera straight to an external display via Mini HDMI.
Video Recording Resolutions: 1080P, 720P, WVGA, and VGA.
Audio: Enable or disable audio for video recording.
Loop Record: Automatically loop recordings and segment them in 3, 5, or 10 minute durations.
Time Lapse Record: Record in time lapse to review footage in time lapse format.
WDR (Wide Dynamic Range): Record in Wide Dynamic Range to capture the best light exposure between different objects.
Motion Detection: Records when camera detects motion.
Date Stamp: Allow the date and time to be captured with recorded footage.
Plate Number: Allows your license plate number to be displayed in video playback.
Accident Sensor: Allows camera to lock the video being recorded during a vehicle collision.
Parking Sensor: Allows camera to power on, to then record and lock video.
Still Image Features
Still Image Resolutions: 3MP, 2MP, VGA, and 1.3MP.
Capture Timer: Enable capture timer to time image capturing.
Burst Shot: Take 3 or 5 consecutive photos in one instance.
Anti-Shake: Take photos with image stabilization.
Quick Review: Temporarily display the picture after it has been taken.
Date Stamp: Allow the date and time to be captured with still images.
Playback Features
Delete: Delete content from MicroSD card using the camera interface.
Protect: Protect files that are written to the MicroSD Card.
Slide Show: View a slide show with 2, 5, or 10 seconds in between images and videos.
Specifications
Feature |
Description |
Model |
ACD-830B |
CPU |
432MHZ Micro-Processor |
SDRAM |
Built-in |
Loud Speaker |
Built-in |
Microphone |
Built-in |
Storage |
via Micro SD Card Slot only |
Micro SD |
Max 64GB Class 10, Min 4GB Class 10 |
Quick Lock Button |
Built-in |
GPS |
GPS compatibility using Mini HDMI port (GPS Module sold separately) |
Battery |
Built-in Rechargeable 3.7V, 200mAh Lithium Ion |
Power Supply |
Output: Mini USB 5V 1.5A; Input: Car Adaptor Socket 12-24V |
Image Sensor |
WDR Sony IMX322 |
Lens Size |
160-degree wide viewing angle |
Display |
3.0 inch TFT 240 x 960 LCD screen |
Video Resolution |
1080 FHD 1920*1080 / 720P 1280*720 / WVGA 848*480 / VGA 640*480 |
Loop Recording |
3 min, 5 min, 10 min |
Accident Sensor |
Accelerometer Impact Detection |
Parking Sensor |
Accelerometer Vibration Detection |
Motion Detection |
Pixel Motion Detection |
Auto Power Off |
Delay shut off for 3, 5, or 10 Minutes |
Video Format |
MOV H.264 |
Image Format |
JPG |
Image Resolution |
3MP, 2MP, 1.3MP, VGA |
Display Output |
Mini HDMI |
Reset Button |
Built-in |
Working Temperature |
-4 ° F ~ +149 ° F |
