Push Notification Setup on Amcrest View Pro (iPhone & Android) (1080P HD-CVI)
First you need to have the Amcrest View Pro app open and your camera added to the Device Manager.
1. Tap the top left icon to open the menu.
3. Tap Configuration.
    • HDD Alarm: Select if you want to receive notifications that no disk is detected, there is low space on the disk, or the disk has an error.
Push Notification Interval
Setting the interval for when push notifications appear are show below:
2. Tap the Settings option.
    • PTZ Speed: Pan, Tilt, and Zoom speed sensitivity may be adjusted between 1 and 8. This sensitivity will affect the Live Viewing PTZ Controls (1 being slowest, 8 being the fastest.)
    • Snapshot Burst: Image capture at 1 snapshot, 3 snapshots, or 5 snapshots per burst.
    • Push Notification Interval: The time between each push notification you will receive when an event has occurred. (15s, 30s, 1m, 2m, 5m)
    • Replay Duration: The default replay duration showing you 30s segments, from 5s up to 60s intervals may be selected.
3. Select Push Notification Interval and select the preferred interval duration that best meets your application.
2 out of 4 found this helpful
