How to Setup an Amcrest Camera Using NO IP DDNS (IP8M-MD180E-AI)
Note: Please make sure your device is connected to the internet.
Step 1: Open the web user interface (Web UI) of your camera using a web browser. For more information on how to access the web UI, click here.
Step 2: Click on the Settings icon and select Storage.
Step 3: In the Network menu, select Connection. Enter an HTTP port number into the HTTP Port field. This will be the port number which will need to be entered at the end of the URL to access your device remotely after it has been port forwarded in the router. For instance, in this example we will be using HTTP port 37779. Please note, the TCP, UDP, and HTTP ports as they will need to be port forwarded in your router after this process is complete. Click Apply.
Step 6: After your device is port forwarded, navigate to the web UI, click on the Settings icon and select Network and click on DDNS and ensure NO-IP DDNS is enabled.
Note: After enabling DDNS function, third-party server may collect your device info.
Step 7:Visit https://www.noip.com/and set up an account with NO-IP. Create a hostname, username, and password and complete the signup process. Please make sure to confirm your email address when activating a new NO-IP account. The Dynamic Update Client (DUC) can be used to manage your hosts and groups within your NO-IP account.
Step 8: Return to the DDNS menu for your Amcrest camera. Enter the Domain Name for your camera into the interface.
This will be the hostname created in your NO-IP account.
Step 9: Enter the username and password for your NO-IP account into the interface and click Apply.
Note: The username and password for your NO-IP account can be found in the Account Info tab on your NO-IP dashboard.
