This model features three different night vision modes which allows the camera to view objects at night. It features an IR mode, which allows the camera to use an IR LED to see at night, a white light mode, which allows the camera to use a white light LED to achieve full color night vision, and a smart illumination mode, which allows the camera to use the IR LED to see at night, however, when a motion is detected, the white light LED will flash.
For more information on how to enable or disable different night vision settings, please refer to the details provided below.
Step 1: Ensure your computer is on the same network as the camera and log into the web UI. For more information on accessing the web UI, click here.
Step 2: Navigate to Setup>>Configuration>>Light Settings and select the Fill Light drop down menu.
Step 3: By default, the camera will be set to IR Mode. Select a different night vision setting, such as white Light mode, or smart illumination. Smart illumination will have the IR LEDs illuminate at night, however, will illuminate the white light LEDs once a motion even is detected.
Step 4: Click Save to apply the new night vision settings to the camera.
Note: To disable night vision completely, access the Mode menu and select OFF. Click Save to save and apply the settings .
