The camera will include an installation plate that will be used to secure the camera to the mounting surface. Before installing your camera, please make sure the mounting surface can support at least 3x the weight of the camera.
What’s Needed?
The camera will come with all the parts necessary to install your camera included in the box, however, a Phillips head screwdriver and drill may be required during installation. Please note, if you are using a microSD card to capture recordings (sold separately) please make sure to install it before physically installing your camera. The camera can support up to 256GB.
MicroSD Card Installation
| Locate the hatch on the bottom of the camera and remove it using a Phillips head screwdriver. |
Open the microSD card slot clasp and place the microSD card into the slot gold pins down. Place the clasp over the microSD card and slide back to secure the card into the slot. Then secure the hatch back onto the camera using a Phillip head screwdriver. |
Installing the Camera
Please make sure the mounting surface can support 3x the weight of the camera before installing. A Phillips head screwdriver and drill may be required during installation.
| 1. Place the installation sticker only the mounting surface and drill the holes. | 2. Insert the wall anchors into the newly drilled holes. |
| 3. Align the holes of the installation sticker to the holes on the installation plate and secure the installation plate to the mounting surface using a Phillips head screwdriver. Please note, if using the Ethernet protection kit, do not cut any wires on the camera’s dongle connections. | 4. Align the 3 screws on the bottom of the camera to the installation plate and turn to lock the camera to the plate. Insert the security screw included with the camera into the into the camera and installation plate then use the included torx wrench to secure the camera. Remove the film from the dome of the camera after installation. |
