How To Format A Hard Drive On An AMLINK NVR
This article highlights how to properly format a hard drive on an AMLINK NVR. To format the hard drive, you will need to access the user interface (web UI) for your device via laptop or PC. For more information on how to format a hard drive on your AMLINK NVR please refer to the information provided below.
Step 2: Navigate to Storage>>Disk Management. Select the hard drive you want to format in the interface and click Format.
After the hard drive is formatted all data/recordings etc. will be removed from the drive. The status will also be normal indicating its ready for use in your NVR.
