The tour feature allows the camera to automatically move between a series of preset positions to survey an area. The positions are manually set by the user within the AMLINK Pro app, a max of five positions can be set for a tour. For more information on how to set a tour, please refer to the information provided below.
Step 1: Open the AMLINK Pro app and access the device. Tap the PT icon and use the directional PT options to rotate the camera to a desired position then tap the Add Position icon ().
Step 2: Name the position and tap OK. Repeat the process to set multiple positions within the Favorite menu. To manually access the favorite menu, tap the ( ) icon.
Note: To delete a position, tap the Edit menu, tap and hold the position and tap Delete.
Step 3: Tap the Tour option to access the Cruise Mode menu and enable the Start preset position cruise option. A cruise interval can be set that will allow the tour to active at a set amount of time (1-24hr).
