Before installing your camera, please make sure the installation surface can support up to 3x the weight of the camera. An image of the installation process is provided below.
For more information on how to install your camera, please refer to the information provided below.
Step 1: Use the included torx wrench to remove the 2 screws on top of the camera and remove the dome enclosure.
Step 2: Install a microSD card into the camera (optional). The microSD card is on the side of the camera next to the factory reset button. The camera can support up to 256GB.
Step 3: Place the included installation position map on the ceiling or wall according to the outlet location and drill the installation holes according to the holes on the position map. Insert the expansion bolts (wall anchors) into the holes.
Step 4: Connect any wiring and align the installation holes on the bracket of the camera to the wall anchors and secure the camera to the installation surface using a Phillips head screwdriver.
Step 5: Place the dome enclosure back onto the camera and secure it using the included torx wrench.
