How to Insert a MicroSD card (ASH43)
A microSD card is required to store events outside of the Amcrest Smart Home Cloud. The camera is compatible with up to 128GB and requires a Class 10 or higher microSD card to function. It is highly recommended to ensure the microSD card is properly formatted to FAT32 before proceeding. For more information on how to format your microSD card, click here.
Step 1: Using a Phillips head screwdriver, remove the 2 screws on the security plate on the bottom of the camera.
Step 2: Locate the microSD card slot for the camera, and insert your microSD card into the slot. Press in and release to lock the microSD card into place.
