Sensitivity vs. Threshold
Think about it this way: sensitivity is a measurement of the amount of change in a camera's field of view that qualifies as potential motion detection, and the threshold is how much of that motion needs to occur in order to actually trigger the alarm. It can be thought of like this: for however long there is enough change to satisfy the sensitivity parameter, a threshold meter is silently being filled up until it hit's the trigger point.
