Pinhole Camera Physical Installation (IP2M-PH822B-CAM)
To install the camera on a ceiling or wall, please reference the below diagram as well as the steps:
Prior to installation, please ensure that the installation environment can support at least 3x the weight of the camera and the bracket. THIS IS NOT A WIFI OR PoE DEVICE. An Ethernet cable and included power adapter will be needed to setup your camera.
To install the camera onto a wall, follow the steps below:
- Place the mounting bracket onto the surface you wish to mount your camera.
- Use the self-tapping screws to secure the bracket to the mounting surface.
- Loosen the adjusting screws to adjust the angle of your device. The device can be adjusted in a up or down position.
- Tighten the adjusting screws to secure the angle of the camera.
