How to Adjust the Camera (IP8M-2496E)
When mounting your camera in certain installation environments, such as eaves or other areas which will require you to adjust the direction of your camera, a Phillips head screwdriver will be required to adjust the camera.
Inside the bracket, there is a ball joint that allows the camera to be adjusted to any desired direction. A security screw on the side of the base can be adjusted to loosen the ball joint allowing the camera to move freely.
Note: It is highly recommended to adjust the base of the camera first before physically installing the camera. The camera will not be able to pivot left or right while physically installed.
Preinstallation
It is recommended to adjust your camera in the direction you want before physical installation. If you have not installed the camera yet please follow the instructions below to adjust your camera.
Step 1: Using a Phillips head screwdriver, loosen the security screw found on the installation bracket.
This will loosen the ball joint and allow the camera base to pivot in anyway you need it to move.
Step 2: Move the camera base to a desired position and adjust the camera accordingly.
Step 3: Once the desired angle is set, use a Phillips head screwdriver to tighten the security screw which will lock the camera into place.
After Installation
If you have already installed your camera and need to adjust the angle of the camera left or right, the camera will have to be removed from the installation surface since the bracket will not allow the camera to physically adjust in these directions.
Step 1: Remove the camera from its installation surface.
Step 2: Using a Phillips head screwdriver, loosen the security screw found on the installation bracket.
Step 4: Secure the camera back onto the installation surface ensuring the proper angle has been set.
