How To Install Included Pieces (A6-B)
Included with your A6-B drone are the following items that will need to be physically installed:
x1 720P Camera
x2 Landing Legs
x4 Propeller Blades Guards
For more information on how to physically install the included pieces for your drone, please refer to the information provided below.
Installing the 720P Camera
On the belly of your drone you will notice a connection port for the included 720P camera.
To install the camera, please follow the steps below.
Step 1: Connect the wiring of the camera to the connection port on the drone. Align the notches of the camera with the notches on the belly of the drone.
Step 2: Insert the notches of the camera into the notches found on the belly of the drone. Gently press down on the camera and turn the camera in a clockwise motion to secure the camera to the drone.
Note: The camera should be facing the front of the drone after it has been properly installed.
Installing the Landing Legs
On the bottom of the drone you will notice 4 notches for the included landing legs.
To install the landing legs, please follow the steps below.
Note: The landing legs can be installed in any order however, in this example we are installing the left landing leg first.
Step 1: To begin, align the back notch of the landing leg with the back notch found on the drone and insert the notch of the leg in the notch found on the drone.
Step 2: Rotate the landing leg in a clockwise motion and insert the second notch of the landing leg into the front notch found on the drone.
Step 3: Press in to finish installing the landing leg. You will hear a click sound once the leg is properly secure.
Note: Repeat the process on the other landing leg to finish. The right leg will turn in a counterclockwise motion to secure.
Removing the Landing Leg
Located next to the second notch of the landing leg will be a release button for the landing leg.
To release the landing leg, press and hold the release button and firmly slide the landing leg notch out of the
Installing the Propeller Guards
There are 4 propeller guards which need to be installed onto the drone. Propeller guards protect the drone from damage while in flight. For more information on installing the propeller guards, please refer to the steps provided below.
Step 1: Locate and remove the security tab for the propeller guards.
To remove the security tab, pinch and hold the exposed tab and firmly pull outward to remove.
Step 2: Align the propeller guard to the insertion slot inside the security hatch and gently press down on the tab located on top of the propeller guard. Firmly press the propeller guard into the slot to secure.
Note: A properly inserted propeller guard will not have any notches exposed as shown in the image above. Please make sure to firmly secure the propeller guard into the security slot before use.
Step 3: Repeat the same process for the other 3 propeller guards to complete the process.
