What Mount Is Best For Me?
Amcrest offers several different mounting options for your speed dome camera. Please note the following specifications apply to your camera:
Initial Weight of the Camera: 3kg (6.61lb)
Dimensions Φ160mm x 295mm:
Dimensions In Inches (L x W x H): (6.5" x 6.5" x 11.7")
Please refer to the recommendations below for your desired mounting preference:
Wall Mount: AMCPFA120
Dimensions (W x H x D): 115.0mm x 160.0mm x 38.8mm (4.53” x 6.30” x 1.53”)
Weight of the Mount: 0.53kg(1.17lb)
Weight of the Camera With Wall Mount: 3.53kg (7.78lbs)
Pole Mount: AMCPFA150
Dimensions (W x H x D): 130.4mm x 170mm x 45mm (5.13” x 6.69” x 1.77”)
Mast Diameter: ɸ80~150mm(ɸ3.15”~5.91”)
Weight of the Mount: 1.1kg (2.43lb)
Weight of Camera With Pole Mount: 4.1kg (9.04lb)
Corner Mount: AMCPFA151
Dimensions (W x H x D): 243mm x 170mm x 138mm (9.57” x 6.69” x 5.43”)
Weight of the Mount: 1.7kg (3.75lb)
Weight of Camera With Corner Mount: 4.7kg (10.36lb)
Wall Mounting Arm
Your speed dome camera will come equipped with a wall mounting arm. This wall mount arm is used to secure the camera to the desired mounting surface. Below is a description of the included wall mount arm:
Included with the arm will be 3 M4 screws. These screws will be used to secure the camera to the wall mount of your choice. For more information on installing your camera, refer to the installation manual which can be found here.
