Installation Guide (IP2M-851)
To see a step by step instructional video on the installation of this camera, please click here.
NOTE: Prior to installation, please ensure that the installation environment can support at least three times the weight of the camera and the bracket.
  • Power Drill
  • 3/16 Drill Bit
  • #2 Phillips Head Drill Bit with Extension, or a #2 Phillips Head Screwdriver
  • Hammer
  • Safety Glasses
  • 15/16th Paddle Bit (for in-wall installation)
3. Using a 3/16th drill bit and power drill, drill three holes on the X’s on the installation sticker. This is to allow insertion of the included expansion bolts (plastic wall anchors).
NOTE: Range of the lens: vertical (0°~+65°), horizontal (0°~+355°). When adjusting the camera into position, please ensure that the camera’s enclosure does not block the image or cause reflection of IR light.
3. Drill a hole on the placement sticker on the larger designated opening using a 15/16th paddle bit.
To assemble the RJ-45 cover:
  • Drop the small rubber washer into the plastic housing, then screw on the top cover.
  • Run the data cable through the weatherproof cover.
  • Install the RJ-45 connector to the end of the data cable to terminate the connection.
  • On the female data cable connector on the camera, place the large rubber O-ring around the end of the connector and pull it down. This is to ensure that water does not penetrate this connection when fully assembled.
  • Plug in the data cable and securely tighten the weatherproof RJ-45 cover.
  • Plug in the power cable and carefully insert all the cables into the hole in the ceiling or wall. Push the main cable through.
  • Align the three holes on the camera's base plate with the holes on the sticker on the mounting surface.
  • Insert the three standard installation screws and tighten them with your power drill to secure your camera to the mounting surface.
  • Reattach the dome cover back onto the mounted base of the camera and retighten the hex screws.
