How To Use A Loitering Detection Rule On An Amcrest Camera (IP2M-863EW-AI-V3)
Loitering Detection is used to detect if a person or group are loitering in a specific area set by the user. A preset must be established before adding a IVS rule. For more information on how to setup the rule please refer to the information provided below.
Note: If a preset is already established, click +Preset to add an additional preset.
Step 4: Click Add Preset and use the PTZ directional arrows to set a PTZ preset if needed. Click the Apply icon to save the preset then click OK.
Step 5: Click +Preset and select the created preset. Select IVS, then click Next.
Step 6: Click IVS.
Step 7: Click Add Rule and select Loitering Detection from the dropdown menu. Use your mouse to draw a detection area on the interface.
By default the rule will be set to trigger if multiple people are within the detection area for a duration of 5 seconds. However, you can adjust the duration if needed from 1-600 seconds.
Note: This camera also supports Auto Tracking. This will allow the camera to automatically track the object until it is no longer visible in the detection area or for a duration of 15-300 seconds.
