The Amcrest WiFi Smart Plug turns your iPhone into a home remote you can use with the Amcrest Connect app to turn your electronics on or off from anywhere! Use it with your TV, computer, reading light, or any other electronic you choose! Set a schedule on any device to save energy and money. Now, you have the simplest method to implement home automation without outrageous installation fees, monthly subscriptions, contracts, or unnecessary equipment. With the WiFi Smart Plug, you can hold your home in your hands.
- Remote & Wireless Control
- Smart Charging & Energy Saving
- Automatic Scheduling
- Customer Shutdown Timers
- Plug-and-Play with Wi-Fi Direct Support
- Wi-Fi Range Extending Function
Features:
Remote/Wireless access to devices so you can control them anywhere and anytime with the Amcrest Connect app.
Plug-and-Play set-up with Wi-Fi Direct so you can get started immediately without complex configuration.
Enhanced Wi-Fi Mode so you can strengthen and extend the wireless signal in your home or office.
Automatic Intelligent Charging Protection so you can preserve your smartphone's battery life from degrading.
Scheduled Tasks and Shutdown Timer Utilities so you can customize your control over your devices.
Unlimited capacity for devices on the Amcrest Connect app so you can control however many devices you want.
Compatibility: Requires iOS 5.1.1 or later.
Click here to download Amcrest Connect for your iPhone & iPad.
