Amcrest Surveillance Pro (1080P HD-CVI)
Thank you for choosing an Amcrest HDCVI DVR as your home security solution!
Below, please find links to the CD contents for the HDCVI DVR kits.
Keep in mind, that the software utilities provided here will work for both the 720p and 1080p DVRs.
AMCREST SURVEILLANCE PRO FOR HDCVI 720P/1080P DVRS
The below link will open up a download for the .exe (or executable program) that will allow you to install the Amcrest Surveillance Pro client for Windows computers. Please note that you need to double-click the file that you download to your computer to "run" the installer. After it is finished installing, there should be a shortcut on your desktop to launch Amcrest Surveillance Pro.
Amcrest Surveillance Pro Download Link - Windows Client (EXE)
Once you've gotten the program up and running, you can use the Amcrest Surveillance Pro User Manual in order to learn how to add cameras, configure and manage them.
Please click here to download the .PDF:  Amcrest Surveillance Pro User Manual Download (PDF)
STILL NEED HELP?
Are you having trouble installing this software to your computer? If you are getting any sort of error message or do not know where to click or how to run the program, please take a screenshot or write down the message that you see. Then, please feel free to reach out to our support at amcrest.com/contactus or by calling (888) 212-7538 and one of our tech support agents would be more than happy to assist you!
Still need help? Contact Us
0 out of 1 found this helpful
