Technical Specifications (EI Model NVRs)
To access the technical specifications sheets for your device, please select your model below.
NV4208E-EI_Technical_Specifications.pdf                          NV4208-EI_Technical_Specifications.pdf
NV4216E-EI_Technical_Specifications.pdf                          NV4216-EI_Technical_Specifications.pdf
NV4232E-16P-EI Technical Specifications.pdf                    NV4232-EI Technical Specifications.pdf
NV5232E-16P-EI_Technical_Specifications.pdf                   NV5232-EI_Technical_Specifications.pdf
NV5432E-16P-EI_Technical_Specifications.pdf
