How to Find the Model Number (OBD Tracker)
The model number for your OBD tracker can be found in numerous areas including the packaging the unit came with and on the unit itself. For more information on finding the model number for your unit, please refer to the information provided below.
Finding the Model Number on the Packaging.
If you have the original packaging for your device the model number can be found in two places, on the front of the box as well as the bottom sticker.
On the front of the box:
On the bottom sticker of the box:
Finding the Model Number On the Unit
If you do not have the packaging for your unit the model number can be found on the serial/IMEI sticker on the back of the unit.
For more information on how to find the model number on an Amcrest GPS tracker click here.
For questions regarding Amcrest GPS Technical support please use the form that can be found at: https://amcrest.com/gpssupport
0 out of 1 found this helpful
