How to Setup Email Alerts Using Amcrest Smart Home
Email Setup will be dependent on your specific email provider. In this example, we will be using Gmail. For more information on how to setup email alerts using the Amcrest Smart Home app, refer to the information provided below.
Step 1: Log into your Amcrest Smart Home and tap on your device.
Step 2: Tap on the settings mceclip0.png icon.
Step 3: Scroll down to Email Alerts. Tap on Email Alerts.
Step 4: In the Email Alerts menu, tap on Email Provider and select your email provider from the drop down down list.
Note: We are using Gmail in this example.
Other email SMTP server Information provided below:
Gmail
Yahoo
 has the SMTP server "smtp.mail.yahoo.com" (without quotes) and will use port 465 with SSL encryption, and port 587 with TLS encryption.
Comcast
For further assistance you may submit a ticket via the button below the comments on this page or you may contact us at:  888-212-7538
Step 5: The SMTP Server information and port number should automatically generated. In the Email field, enter your email address and enter the password for that email address in the password field. The email you entered will automatically be added into the Sender field.
Step 6: Enter the recipient's email address into the Recipients Email menu. Make sure to tap the (+) icon to successfully add the email address into the Recipients Email menu.
Step 7: Tap on the Save icon to save your configuration. Tap on the Email Test button to test the email connection.
Note: Check you email and make sure the Email Test notification went through properly before proceeding.
Once your Email information is entered and the Email test has been sent successfully, tap on the back mceclip0.png icon to return to the Device Information menu.
Step 8: In the Device Information menu, scroll up and tap on the Motion Detection menu.
Step 9: Enable the Email Notifications and the Email Snapshots toggle switches to activate Email snapshots and notification to be sent to your Email address.
Email alerts have now been properly enabled on your device. Use the back mceclip0.png icon to return to the live view screen.
