How to Setup an Amcrest NVR/DVR on Amcrest View Pro Using P2P.
The Amcrest View Pro app allows you to access your NVR or DVR from your smartphone. The app is available on both the App and Play store. For more information on how to setup your device on the Amcrest View Pro app, please refer to the information provided below.
Note: Before proceeding, please make sure the device and your smartphone are connected to the same network.
Step 1: Download the Amcrest View Pro app from the App Store or Play Store and open it. Please allow all permissions if requested.
Step 2: Tap DVR/NVR.
Step 3: Tap “P2P Connection”
Step 4: Scan the QR code. The QR code can be found on the serial tag along with a scannable barcode.
Step 5: Create a name for the device and enter a username and password. If this is your first time logging into the device, the default username and password will be admin. Tap Start Live View
If this is your first time logging in, update the default password for the device and tap Start Live View to access the device.
0 out of 2 found this helpful
