How to Setup DDNS on your Device
To setup DDNS on your device, you will need to access the web user interface (web UI) for your device on a laptop or PC. For more information on how to access the web UI, click here
Step 1: To setup DDNS service you will need to port forward your device. For more information on how to port forward your device, click here
Step 2: After your device is port forwarded, navigate to the web UI and click on Setup>>Network>>DDNS and enable DDNS service by clicking on the Type check box.
The DDNS provider will be defaulted as AMCREST DDNS, please leave this selection as AMCREST DDNS. Additionally, the server address will be www.amcrestddns.com.
Step 3: Enter a Domain Name. Please note, it is highly recommended to use a unique domain name when setting up DDNS as any common names such as "amcrest" "camera", etc. may not work as it is already being used by other devices.
Step 4: Click on Save to save the DDNS settings to your device.
Accessing the Device on DDNS
The DDNS address you will use to access your device will be formatted as follows in the web browser, "domainname.amcrestddns.com:port#" For instance, if you used "mycamera" as your domain name, and 37779 as the HTTP port number, the DDNS IP address used will be formatted as following:  "mycamera.amcrestddns.com:37779".
The update period for your DDNS service will be set to 10 minutes. It is recommended to leave this as 10 unless otherwise instructed.
