How To View MicroSD Card Recordings (AD410)
A microSD card can be used to store events from your doorbell. The doorbell is compatible with up to 128GB of storage.
Note: Please ensure you are using a class 10 or above microSD card that does not exceed the storage limitation of your doorbell (128GB). The microSD card must be formatted to FAT32. This may have to be done manually as most programs do not format this allocation automatically. For more information on how to format your microSD card to FAT32, click here
On the back of the device locate the MicroSD card slot. Raise the MicroSD card flap and insert the MicroSD card, gold pins down. Secure the flap back to the doorbell.
