How To Use a Fisheye Camera In Amcrest Surveillance Pro
Dewrapping features, such as those available in the Amcrest fisheye camera, can be used in our free Amcrest Surveillance Pro software. For more information on how to add your camera into Amcrest Surveillance Pro, click here.
For more information on how to use the fisheye feature for your camera in Amcrest Surveillance Pro, please refer to the information provided below.
Step 1: Access your camera in the Surveillance Pro software and access the live view screen.
Step 2: Right click on the live view screen to highlight additional features for your camera. You will notice the "Fisheye Installation Mode" and "Fisheye View" options available in this menu. This will be how the camera is controlled. Each fisheye view will change based on the selected preference.
  • Fisheye Installation Mode - The installation mode features allow you to switch between different play modes based on the angle of view of your camera. Activate a installation mode to begin using any fisheye view features.
Ceiling Mount Mode:ceilingmount1.png) - Allows the user to access preset fisheye features based on a ceiling or straight mount installation.
Fisheye Features Include:
Wall Mount Mode:image2.PNG ) - Allows the user to access preset fisheye features based on a wall or side ways mount installation.
Ground Mount Mode:mceclip1.png ) - Allows the user to access preset fisheye features based on a ground position mount installation.
