How To Change an Amcrest Smart Home Cloud Plan
Any changes made to your current Amcrest Smart Home cloud plan will take effect on the next billing cycle. All Amcrest Smart Home Cloud plan changes are made via the Amcrest Smart Home app. For more information on how to change your current Amcrest Smart Home Cloud plan, please refer to the information provided below.
Step 1: Open the Amcrest Smart Home app and log into your account.
Step 2: Tap on the Account tab.
Step 3: Tap on My Plans.
Note: The My Plans menu will display all past and present Amcrest Smart Home Cloud plans, unpaid, paid as well as cancelled plans. You can filter this via the "Unpaid", "Paid", and "Cancelled tabs".
Step 4: Select your current plan from the My Plans menu.
Step 5: Tap on Change Plan. Read the provided information on the screen and tap "Change Plan" to continue.
Step 6: Select which plan you would like to change to from the Amcrest Smart Home cloud plans provided. Tap Buy to continue.
Step 7: Choose whether you would like to auto renew your payment. Tap Confirm Payment to continue.
Step 8: Enter your Name, and billing information into the app. This will be the billing information used for the new plan you have selected. Tap Pay to complete the process.
