How To Activate Smart Notifications
Smart notifications are push notifications that are sent to your phone which let you know a motion or other event has been detected. These actions can range from a motion being detected by your device by a call coming through from someone using your Amcrest WiFi doorbell.
Activating Smart Notifications
Smart Notifications can be turned on or off using the Amcrest Smart Home app. These settings are account based and not necessarily based per device. To turn smart notifications on or off, log into your Amcrest Smart app and tap on the Account menu.
In the account menu, scroll down to the "Push Notification" menu. You will notice 2 toggle switches, one for your devices and one for shared devices.
Use these toggle switches to turn smart notifications on or off for your devices or for shared devices. If you would like to turn off motion detection events you can based on device in the Devices menu. To turn off motion events per device toggle the "running man" icon (push21.png) to the off position.
