How Do I Flip the Image? (Battery Camera)
When installing your camera it is important to note the direction in which you want your camera to face. If the image of your camera needs to be flipped, access the live view interface of your camera in the app and tap on the settings ( gear21432.png ) icon in the upper right corner of the screen.
In the settings menu, tap on the “Flip Image” toggle switch to enable and flip the image. The image can only be flipped in a 180° motion.
