What's Included? (DVR)
The DVR you have purchased will come with the following items:
  • Amcrest DVR Quick Start Guide
  • An Ethernet Cable (For the DVR)
  • A Power Cable/Adapter (For the DVR)
  • SATA Cables (For Hard Drive Installation)
  • A Power Supply Cable (For Hard Drive Installation)
  • Security Screw (For Hard Drive Installation)
Note: A hard drive may not be included with your purchase and would have to be purchased separately from the DVR.
Below are the two most common areas to locate the included SATA cables:
In the box that is included with the DVR's power supply and adapter.
In the container with the Ethernet cable and DVR Quick Start Guide.
