How To Create and Manage Zone Alerts.
Zone Alerts can be created via the Zone Alerts tab or can also be created after the creation of a custom zone. For more information on how to create a custom zone click here.
Creating A New Alert
Once you have completed a custom zone, you will be prompted to fill out a new alert form. This form will denote; the alert name, the device (asset), the zone the alarm is being applied to, the phone number associated with the device, email address, and an optional second phone number and email address.
The alarm name can be customized to fit the name of the zone or can be any name you want. Next, you will choose the name of the device you wish to apply the alarm notification to. The next selection will be to enter the phone number the device is associated with and then enter the email address associated with device. If you would like to enter an additional phone number and email address where you would like the alerts to be processed, you may enter this information in as well however, please be aware this information is optional and not required to proceed with the alarm activation process. To complete the alarm setup procedure please press “Create Alert” to save the alert settings and apply them to your newly created custom zone.
Once you have successfully created your alert, the app will prompt you that your alert has been successfully created.
Editing an Alert
To edit or modify an established alert on the app, please tap on the icon located in the alerts menu. This will take you to an option to edit the alert.
Once you have tapped on the alert you would like to edit, you will notice a Zone Alert Edit menu. In this section you can edit the following options:
Alert Name – Allows you to change the name of your set alarm.
Zone – Allows you to change the custom zone of the alert.
Device – Allows you to choose which device you would like the modification to be applied.
Phone 1 – Allows you to edit the primary phone number associated with alert.
Email 1 – Allows you to edit the primary email associated with the alert.
Phone 2: This is an optional setting that allows you to edit a secondary phone number associated with the alert.
Email 2 – This is an optional setting that allows you to edit the secondary email address associated with the alert.
Once this information is complete, please select “Update” to apply to changes to your alert settings.
Deleting an Alert
To delete an established alert on the app, please tap on the  icon located in the alerts menu. This will take you to an option to delete the alert.
Once the delete option has been selected the app will prompt you as to whether you would like to proceed with the deletion process. If you would like to proceed, please select “DELETE” to complete the process.
