How To Adjust An Amcrest Bullet Camera
This model camera does not allow automatic adjustments. All adjustments to the device will have to be performed physically at the camera. There are three basic ways to adjust your camera; right or left, up and down, and on a 360° swivel. For more supplemental information on how to adjust your camera, please refer to the instructional guide provided below.
To begin adjusting your camera, locate the three Phillips head screws towards the base of the device. These screws are used to adjust the position of your camera.
Bottom Screw: To adjust your camera right or left, loosen the bottom (base) screw with a Phillips head screwdriver. Once loose from the bracket the camera will be able to rotate in a right or left motion. After you have adjusted your camera, make sure to tighten the screw to lock the camera into your set position.
Middle Screw: To adjust your camera up and down, loosen the middle screw. Once loose you can adjust the camera in a up and down motion. After you have adjusted your camera, make sure to tighten the screw to lock the camera into your set position.
Top Screw: To adjust your camera in a 360° motion, loosen the top screw and move the camera to your desired position. After you have adjusted your camera, make sure to tighten the screw to lock the camera into your set position.
