How To Insert A MicroSD Card (IP5M-1176E)
How To Insert A MicroSD card Into The IP5M-1176E
To insert your SD card to the camera, please place the camera in the fitted SD card slot placing the SD card's gold plated connectors with the cameras gold plated locking pins:
0 out of 1 found this helpful
