How To Insert A MicroSD Card (IP4M-1056E)
How To Insert A MicroSD card Into The IP4M-1056E
To insert your SD card to the camera, please place the camera in the fitted SD card slot placing the SD card's gold plated connectors with the cameras gold plated locking pins:
