How To Insert An SD Card
Note: For more efficient service, please make sure you are using a maximum of 64GB, class 10 or above microSD card.
The microSD card slot is located on the back of the camera. Please remove the back plate on the back of your camera with a Phillips head screw driver to proceed:
Please ensure that the microSD card's brass (gold plating) is facing up. then firmly slide the SD card into the slot until you hear a small click. This click will indicate the microSD card is in place and secured in the unit.
