Amcrest Surveillance Pro: Adding A Camera
Amcrest Surveillance Pro: Mac OS / Windows
The camera will now appear in the bottom table. In the "Operation" column select the pencil icon .
After the camera has been added you can setup a storage device through PC-NVR within Amcrest Surveillance Pro to record video files directly to the HDD stored on your computer.
Also, you can view each of your cameras simultaneously through Amcrest Surveillance Pro through the Live View menu!
